Today I ran into an issue with the filament not sticking to the build plate. However, the strange part is, that this only happens with one filament color (both PLA, khaki, black works just fine) and only in the main print. The test line on the side of the bed and the brim all stick without a problem. I already releveled everything and as I'm using ABL and the other filament works fine, this shouldn't be the issue.
I also tried increasing the first layer thickness in Cura, however, this leads to extreme warp (2 mm height on 5 mm width).
From my observations, it seems that the print head is raised after the brim is printed. Is there a setting in Cura to change that?
Printer Details: Modified Ender-3 with MKS Gen L V2 Board and TMC 2209 motor drivers and BLTouch
Print temp: 220 °C / 70 °C initial after that 200 °C / 60 °C
Firmware: Marlin, details here
