My printer was working fine two weeks ago, I traveled cross country with it (making sure it was secure while moving) to a place of significantly lower elevation. Nothing has printed well since I got here, including the print I did two weeks ago (same settings). I've adjusted flow rate, extruder temperature, infill density and style, fan settings, and releveled the bed, and I still have really brittle layers that don't hold together. It's almost like the nozzle is moving up and down on each layer in a pattern.
    $\begingroup$ Hi, welcome to 3DPrinting.SE! An image of your printed objects would help a lot. $\endgroup$ – 0scar May 19 at 21:45
  • $\begingroup$ What type of bed do you have ? $\endgroup$ – Stefan Merfu May 20 at 12:09
  • $\begingroup$ What material are you printing? Do you have a printer model? $\endgroup$ – Perry Webb May 20 at 14:34
  • $\begingroup$ Are the thermistors measuring temperature correctly. $\endgroup$ – Perry Webb May 21 at 14:22
