I am very new to 3D printing and I cannot figure out what is the problem is. I have checked all of the belts and (to the best of my knowledge) they are tensioned properly. I also did the bed leveling, however it is manual and I did this by putting a paper between the nozzle and the print bed.
I think that my extruder is calibrated, in the sense that when a command is sent to extrude 50 mm of filament, it does. I am unsure what else to check.
The attached image had 15 % infill in the cubic pattern and had ironing on for all layers, was sliced with Cura and printed on a Creality Ender 3 V2. Sorry about the huge size of the image.
The part that looks zebra-like should be smooth.
Photo of not smooth print
  • $\begingroup$ I haven't tried ironing it but I don't think it will always be perfectly smooth. By the way I suggest you look your settings and re-slicing. Or try printing a nicely sliced ironing enabled model. You can print a 10x10 mm calibration cubes to try it out. $\endgroup$
    – user30878
    May 27, 2021 at 8:43
  • $\begingroup$ Z heights are the problem. I had that problem 5 years ago, $\endgroup$ Jun 25, 2021 at 23:17
  • $\begingroup$ @FernandoBaltazar How do I fix this? $\endgroup$ Jun 30, 2021 at 1:12
