I just got my new CR-10 Max and got it assembled. I turned it on, was auto-leveling it, and I received a slight shock from the leveling bed and the frame. Is this a grounding issue? I haven't even printed anything yet and this happens. Anyone have any tips or heard this happening before? I've sent 3 emails to Creality already and gotten no response.
    $\begingroup$ It's probably a harmless thing related to the noise filtering in the power supply. You can fix the issue by grounding the printer. It's been discussed before on this site. $\endgroup$ May 27 at 20:29
  • $\begingroup$ If the above link doesn't help, are you sure its not your bodies ESD to ground. $\endgroup$
    – Perry Webb
    May 28 at 12:43
