I have an Ender 3, currently in stock Bowden extruder configuration.
I want to be able to print nylon and TPU, both of which require temperature too high for the tolerance of the PTFE Bowden tube (as well as the issues with the flexible filament in the tube).
Therefore, I've considered converting my printer to direct drive. However, the conversions I've seen, both DIY/print the parts type and commercial, seem to include a short length of the same PTFE tube between the extruder (now mounted on the hot end carriage) and the actual hot end. This same material ought to have the same temperature limit (about 250 C) as it would have in a Bowden configuration -- and for nylon, at the least, this is a problem, since the PTFE would start to soften from contact with the heat break.
Am I missing something in these conversions, or is the PTFE's glass transition not the limiting factor in printing hotter with a direct drive conversion?
