I have recently started printing with Polymaker's PolyMax PETG on my Ender 3 v2. I have not been able to get the layer adhesion anywhere near as strong as it should be. I would guess it is around 20-25 % of the strength in the XY direction. The parts snap easily along the layer lines under loads that PLA and nylon hold up to just fine.
Print settings:
- 0.15 mm layers @ 35-20 mm/s
- Hotend temp 245 °C
- 4 mm retraction @ 40 mm/s
- combing on
- jerk control on
- no cooling
I made sure to use a nickel-plated brass 0.4 mm nozzle. I have calibrated my E-steps and tried printing in an enclosure, but nothing seems to help with layer adhesion. I have made sure there is no debris getting on the filament as it comes out of the drybox and even tried taping around the heater block so there is absolutely no part cooling.
Any ideas as to what I could be doing wrong?
