I am looking to print an HTD Timing Belt pulley to be used in a laboratory setting that can get very cold for extended periods of time. By "very cold" I mean adjacent metal chambers get cooled with liquid nitrogen to lower than -200 °C. For the purposes of having a threshold temperature tolerance, assume that the metal chambers coming directly in contact with the pulley may get as cold as mK close to absolute zero.
While it was my intention to print this pulley out of PLA, I am unsure whether or not it will be able to withstand negative temperatures of this magnitude or if it will become brittle--or something else will happen to the structure of the print when it experiences these temperatures. I am open to printing any other material if there are some materials that will hold up better than PLA for low temperatures. It is preferable for me to print this part instead of machine it for the sake of a deadline. I was also wondering if there is some infill pattern, infill density, or other structural print parameters that would help reinforce a printed part against becoming brittle when imposed to such low temperatures.
