My 3D printer has got a clog, and i think it is because the nozzle hole has just recently started to only screw in crooked. I’m not sure how this happened. I have tried with multiple nozzles, but they all screw in crooked. Is there a way to fix this? Or is my only option to get a new hotend.
My 3d printer is an Ender 3
    $\begingroup$ The technical term for this is "cross threading". $\endgroup$ Jun 24 at 7:09
    $\begingroup$ Note: if the threads on the heater block and /or nozzle have residual filament material on them it is easy to cross--thread the nozzle, especially when cold.. In this case it is easier to attach the nozzle with the heater hot so the filament material is soft. $\endgroup$
    – Perry Webb
    Jun 24 at 14:37
You should be able to purchase only the heater block for your hot end. The nozzle should thread in by hand without undue force. Having to use a wrench at the outset is an indication of a problem which should have stopped the attempt.
There are many sources for the "heater block for Ender 3" when used in a search. One such result is an Amazon seller of three pieces for US$11.99
amazon heater block for ender 3
Image via linked site.
