I recently did a G29 (run mesh calibration) and my printer did a 25 point probe and reported back the stats to the console. After this I went to the height map section and it says "height map not available" and no stats can be used here.
So I tried to load the height map using G29 S1 and am getting:
G29 S1 Error: G29: Failed to load height map from file heightmap.csv: Could not find file '/opt/dsf/sd/sys/heightmap.csv'
Does anyone know what I am doing wrong? Below is info about my control board and firmware.
RepRapFirmware for Duet 3 MB6HC version 3.1.1 running on Duet 3 MB6HC v1.01 or later (SBC mode)
