I've upgraded my board to SKR1.4 Turbo with RepRap firmware. Everything works, but motors move double the request. M112 reports them as 'no-driver-detected'.
    M112
    === Diagnostics ===
    RepRapFirmware for LPC176x based Boards (biquskr_1.4) version 3.2.2_2 running on LPC176x at 120Mhz
    Used output buffers: 3 of 16 (16 max)
    === RTOS ===
    Static ram: 4956
    Dynamic Memory (RTOS Heap 5): 8232 free, 8192 never used
    Allocations: 188 Frees: 34
    Never used RAM 256, free system stack 18 words
    Tasks: NETWORK(ready,195) HEAT(blocked,243) MAIN(running,358) IDLE(ready,21)
    Owned mutexes: WiFi(NETWORK)
    === Platform ===
    Last reset 00:05:40 ago, cause: [software]
    Last software reset at 2021-07-06 23:53, reason: User, GCodes spinning, available RAM 80, slot 2
    Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00425000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
    Error status: 0x04
    Aux0 errors 0,0,0
    Supply voltage: under voltage events: 0
    Driver 0: position 37762, no-driver-detected
    Driver 1: position 37762, no-driver-detected
    Driver 2: position 37762, no-driver-detected
    Driver 3: position 0, no-driver-detected
    Driver 4: position 0
    Driver 5: position 0
    Driver 6: position 0
    Date/time: 2021-07-06 23:59:06
    Slowest loop: 9.08ms; fastest: 0.10ms
    Step timer: target 197699275 count 340845874 delta -143146599 late 0
    USBSerial connected 0
    ADC not ready 2 ADC error threshold 10 ADC Init 1
    Ints: 0; Calls 0; fast: 4294967295uS; slow 0uS adj 0 bad 0 big delta 0
    PWM Channels
    Delta -1660064855 Start -1 End -1
    === Storage ===
    Free file entries: 6
    SD card 0 detected
    SD card longest read time 1.5ms, write time 0.0ms, max retries 0
    === Move ===
    DMs created 40, maxWait 159279ms, bed compensation in use: none, comp offset 0.000
    === DDARing ===
    Scheduled moves 21, completed moves 21, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 12], CDDA state -1
    === Heat ===
    Bed heaters = 0, chamberHeaters = -1
    === GCodes ===
    Segments left: 0
    Movement lock held by null
    HTTP is idle in state(s) 0
    File is idle in state(s) 0
    USB is idle in state(s) 0
    Aux is idle in state(s) 0
    Trigger is idle in state(s) 0
    Queue is idle in state(s) 0
    Daemon is idle in state(s) 0
    Autopause is idle in state(s) 0
    Code queue is empty.
    === Network ===
    Slowest loop: 191.40ms; fastest: 0.00ms
    Responder states: HTTP(2) HTTP(0)
    HTTP sessions: 1 of 2
    - WiFi -
    Network state is active
    WiFi module is connected to access point
    Failed messages: pending 0, notready 0, noresp 0
    WiFi firmware version 1.25-01LE-D
    WiFi MAC address 74:59:09:3b:82:bd
    WiFi Vcc 2.93, reset reason Turned on by main processor
    WiFi flash size 4194304, free heap 36360
    WiFi IP address 192.168.0.200
    WiFi signal strength -80dBm, mode 802.11n, reconnections 0, sleep mode modem
    Clock register 00181001
    Socket states: 0 0
But M569 seems to be able to communicate with the drivers:
    M569 P0
    Drive 0 runs in reverse, active low enable, timing fast, mode stealthChop, ccr 0x00053, toff 3, tblank 0, tpwmthrs 2000 (4.7 mm/sec), pwmScaleSum 0, pwmScaleAuto 0, pwmOfsAuto 0, pwmGradAuto 0, pos 0
    M569 P0 D2
    M569 P0
    Drive 0 runs in reverse, active low enable, timing fast, mode spreadCycle, ccr 0x00053, toff 3, tblank 0, hstart/hend/hdec 5/0/0, pos 0
As you can see, I managed to change the setting from 'stealthChop' to 'spreadCycle'.
I also tried editing the config.g to check if the stepping is set correctly and, unfortunately, it is.
Both M350 X16 Y16 Z16 E16 I1 and M350 X256 Y256 Z256 E256 make the stepper motors run twice the distance in mm required.
I can fix this problem by setting the steps per mm from 80 to 40, but I always ran 80 and online calculators say that my steps/mm are 80.
Is there something that I missed checking? How is it possible that the motors spin twice the required?
  • $\begingroup$ Hi Chris and welcome to SE.3DP. +1 for an intriguing and well presented question. Hopefully someone may be able to answer your question in a few days. Good luck! $\endgroup$
    Jul 8, 2021 at 1:21
