I have been battling print issues since my purchase of a new Creality CR-6 SE. I chose to do a firmware upgrade to see if it's perhaps a patched issue. I used the Creality Download page and downloaded the zip containing the 4.5.2 mainboard firmware for CR-6 SE.
I cleared an SD card and then put the .bin found/named (CR-6SE 32bit mainboard firmware\4.5.2mainboard (C & E version/CR-6SE - V1.0.2.bin)
It loaded and then I had no text. I tried the next bin in the same folder, the same result... continued through all of them with the same result.
It appears that the other printer functions exist, I was able to run the bed leveling processes successfully, just no text is present to label anything or to indicate when it's working.
How do I get the text to return to my display?
Bonus: I navigated to the settings menu and clicked the language menu item (using icons to navigate) and then the printer UI freezes. I have to power cycle to interact with it again.
