I have an Ender 3 Pro with a BLTouch 3.1 attached and I have this weird problem. Whatever I print, whether it's a 3rd party STL or my own design, the Z is always getting stretched up to a point and then it fixes itself.
i.e. I printed these calibration cubes at 100% and 150%. While there is a slight wobble on the X axis, X, Y and the top half dimensions are almost perfect.
Z prints higher than it should
Not sure if I had this problem prior to BLTouch installation, so I suspect that it might be messing Z jump between the layers somehow but no idea what to look for.
I am using TH3D's Marlin Firmware and I did nothing other than enabling the corresponding flags for BLTouch and ENDER_V44_BOARD when compiling the firmware.
  • The problem occurs on my custom designs and other models too, so it's definitely not the model
  • I tried to use Simplify3D, Ultimaker Cura, Prusa Slic3r to slice and then print with Octoprint, Simplify3D or Pronterface, it didn't make a difference.
  • I calibrated the E steps, so I am not no under or over-extruding.
  • I also tried to re-calibrate the Z steps so the height would match, which it did but didn't solve the problem. I now have a squished top half and a weird looking print.
  • The steps/mm values were at default, X80, Y80 and Z400 - as described, reducing the Z to 320 to compensate the height difference didn't help. See the picture below.
Squished top half after reducing the Z steps
I am pretty much stuck at this point, so I'd appreciate any guidance very much!
It seems the DEFAULT_LEVELING_FADE_HEIGHT of the TH3D firmware was causing the issue, which was something I was aware of but didn't think that it would cause this.
I set it to zero and then re-printed the calibration cube. It came out with the dimensions of 20 mm x 20 mm x 20.1 mm, which was incredibly accurate for the setup I have.
Related: Creality Ender 3 Pro - Z travel issue with TH3D firmware
  • $\begingroup$ Nice. Yet another reason I don't feel the need for BLTouch. $\endgroup$
    – Zeiss Ikon
    Aug 3 '21 at 13:07
