I have a Tevo Tornado, it seemingly connects fine, it is recognised by the software and it turns on. Any command I send over USB is not executed, as if it's not registering them. I tried on Cura and Pronterface and the printer is unresponsive. In particular in Pronterface it displays:
echo:busy: processing
but nothing is executed.
This is part of a broader set of problems I am trying to diagnose on the printer; most of them are explained in this question. I am trying to section off the individual problems and fix, bit by bit, the whole printer.
  • $\begingroup$ What command(s) did you send that got that response? Valid gcode? $\endgroup$
    – Zeiss Ikon
    Aug 5, 2021 at 13:28
  • $\begingroup$ Anything from homing to a G-Code file to print. $\endgroup$
    – delghen
    Aug 5, 2021 at 13:42
  • $\begingroup$ Have you tried a different USB cable? $\endgroup$
    – agarza
    Aug 5, 2021 at 17:26
  • $\begingroup$ Yes. FYI this is part of a broader set of problems I'm trying to diagnose on the printer. If you are curious you can find most of them explained in this question: 3dprinting.stackexchange.com/questions/16790/… I'm trying to section off the individual problems and fix, bit by bit, the whole printer. $\endgroup$
    – delghen
    Aug 5, 2021 at 20:06
