While doing the setup of a new machine I printed a small retraction test which showed that layers at different heights present a varying section. The whole area of the layer is expanding and contracting similarly in both the x and y directions and simultaneously in both the towers.
The layer area is very small and I did not see the same effect printing larger parts.
The printer has a long bowden tube, and that may be a source of a number of weird behaviors. But what I like to think is a squish resonance: let's say that for any reason (even a mechanical one) the height of a layer is slightly larger, the deposed material will not get squished out as far as for the previous layer, resulting in a slightly taller layer but with smaller cross section. Depending on how the situation evolves, we may hit the opposite case few layers later, with the top of the print that has raised close to the nozzle so the layers now are getting squished more.
I could do several more tests with other temperatures, different filaments... but it is quite a corner case, so I do not really need to invest a bunch of time studying it, still I would like to get a better understanding of the phenomenon.
    $\begingroup$ Do you have some reason to believe in inconsistent material flow or inconsistent Z positioning? $\endgroup$
    – Davo
    Aug 6 '21 at 12:17
    $\begingroup$ If you're printing that object by itself, that is a difficult print due to lack of time to cool. Have you tried printing multiples of the same object in a single print? $\endgroup$
    – Perry Webb
    Aug 6 '21 at 16:16
  • $\begingroup$ It may be informative to see if the issue is still seen with all forms of retraction disabled. Or if available for your printer a test of the same print with stock default slicer settings. $\endgroup$
    – Kezat
    Aug 8 '21 at 2:37
  • $\begingroup$ If this is a standard off the shelf printer, information as to the model of printer might be helpful. Along with the slicer used. $\endgroup$
    – Kezat
    Aug 8 '21 at 2:40
    $\begingroup$ @craftxbox the bed was heated very slightly to 40 C. It is a very large bed 500x500 mm and I was printing in a corner on the top of a supporting screw, which is not directly heated. I will see if I can get some time to do further experiments, but, as stated in the question, that is very low priority now. $\endgroup$
    – DarioP
    Aug 12 '21 at 6:19
