3D rendering of four models
Using Cura or another slicer if needed, how could I print the part that needs bending using a structure similar to the one used for rafts.
In Cura, for reference they look like this:
A Cura preview of an open raft
A Cura preview of a raft with crosshatch
A Cura preview of a horizontal raft
A Cura preview of a raft 90 degrees to the previous model
I know this structure is probably good enough for the base of this object, even though other problems may arise later. So how can I have something close to this structure in Cura for a part of the model?
  • $\begingroup$ Does "Different infill in the same part" answer your question? You can e.g. use different infill or different shells, e.g. no shells or walls. $\endgroup$
    Aug 25 '21 at 21:30
