I've heard a bit about folks using air compressors with tubing to the toolhead and outlet openings there as part cooling. One example is the Berd Air, but from the information I can gather, it works with rather low pressures where the expansion of the compressed air is unlikely to get the air significantly below ambient temperature, so it's basically equivalent to a low-end fan. Indeed, this video comparing such a system against the HevACS found it rather ineffective.
If one wants to harness the cooling of compressed air to hit the part with air significantly below ambient temperature, what is the relationship between pressure needed and temperature drop? I assume one can work it out pretty closely with ideal gas law, but I don't understand how to figure in both the change in volume and pressure when the air exits the high pressure part of the system.
    $\begingroup$ This question could be regarded as a physics question as it involves thermodynamics. $\endgroup$
    Commented Sep 1, 2021 at 9:03
    $\begingroup$ Indeed it has overlap of physics, engineering, and 3d printing, but the context is very much the latter. $\endgroup$ Commented Sep 1, 2021 at 13:13
    $\begingroup$ While compressed air comes out cold, from the decreasing pressure, the air in the line would be at room temperature, so little blasts might not cool the same as a steady stream from the compressor. Also cold air, vs room temp air might not be great for 3D print cooling, I think it would cause warping in many materials, because the plastic keeps shrinking the colder it gets. Once you’re past the glass temperature, you have no practical reason to cool it further. $\endgroup$ Commented Sep 2, 2021 at 20:19
  • $\begingroup$ @ChinchillaWafers: "Air in the line"? If you're doing this, you put the TX valve right at the toolhead both for the sake of flow and avoiding absorbing heat after decompression. The point of colder air is not to get the final temperature cooler but to cool quicker, since rate of cooling is proportional to difference in temperature. Ambient air at 23 ˚C rapidly cools the material from its initial temperature of 210 ˚C, but cooling is far slower by the time it reaches Tg. Getting the cold air down to near 0 ˚C (much lower is probably a bad idea for risk of freezing up) would help a lot. $\endgroup$ Commented Sep 2, 2021 at 20:28
Maybe you're thinking of 'Vortex Cooling' which uses a tuned vortex tube to create hot and cold airstreams. The Wikipedia example uses 100 SCFM of filtered compressed air at 100 PSI to create a 70 °C temperature differential.
Here's one on Amazon which is targeted at milling applications. Here's another...
  • $\begingroup$ No, I'm thinking about exactly what I asked about. I'm not sure whether this is an interesting alternative though; it may be. $\endgroup$ Commented Sep 7, 2021 at 4:20
  • $\begingroup$ From what I gather, it uses some trick to get the resulting temperature significantly below what it would be just from the expansion of the gas. That's very interesting, but probably not a direction I'd go because of excess toolhead mass - I want to use this eventually on a delta with an extremely light toolhead. And it'd likely bring the temperature so low you'd be dealing with ice. $\endgroup$ Commented Sep 7, 2021 at 4:27
  • $\begingroup$ @R..GitHubSTOPHELPINGICE, As shown on the first link, you can pipe the cool air where you need it- a lightweight, flexible plastic tube would do. $\endgroup$
    – BobT
    Commented Sep 7, 2021 at 14:43
Firts of, I created a quick simplified simulation in Matlab of cooling from 210°C to bellow 50°C. Here is a plot showing the difference in temperature curves in time. As stated, it is simplified, because I guessed that a printed piece can get from 210 deg to 50 in less than 5 seconds when cooled properly to room temperature.
I used this differential equation:
where T is temperature, t is time, T_target is target temperature (temperature of cooling air), a is a constant which I adjusted to meet the above specified criteria (a = 0.5)
As you can see, you save about a second of cooling time. You say whether it is enough. In my opinion it is irrelevant for standard printing.
Here is the Matlab source code if you want to try and experiment with it (it might run in GNU Octave as well, but I haven't tried it):
clear;
clc;
a = 0.5;
targetTemp1 = 23;
targetTemp2 = 0;
tempLine = 50;
timeSpan = [0, 5];
x0 = 210;
[t1, y1] = ode45(@odeFcn, timeSpan, x0, 0, a, targetTemp1);
[t2, y2] = ode45(@odeFcn, timeSpan, x0, 0, a, targetTemp2);
figure("Position", [360, 1220, 1200, 800]);
hold on;
plot(t1, y1);
plot(t2, y2);
plot([timeSpan(1), timeSpan(end)], [tempLine, tempLine], "Color", "black", "LineWidth", 2);
grid on;
legend("Taget temperature: " + targetTemp1, "Taget temperature: " + targetTemp2);
xlabel("t[s]");
ylabel("T[\circC]");
function y = odeFcn(t, x, a, target)
    y = -a * (x - target);
end
That being said, here is how I calculated the needed pressure.
Constants:
c is specific heat capacity of air, κ is Poisson constant for air, ρ is density od air, V_2 is volume at atmospheric pressure, I estimated this value, Δt is temperature difference assuming the pressurized air is at room temperature and need to be cooled down to 0 degrees
The needed energy too cool the air by delta t is given by this formula:
And assuming this is adiabatic process with ideal gass, we can use this equation to find p1:
assuming V1 is given by:
I calculated the needed work W is 0.3 J and the pressure p1 is 148 kPa. To me this seems fairly low, I might have made a mistake somewhere or a wrong assumption. However, I would always suggest experimenting and finding an answer empirically, because there are too many unforseen variables like: air humidity, parts that would absorb/release the heat, direction and speed of the airflow, crossectional area of the outlet and so on.
Hope this helps.
[Edit] You can find the equations on wikipedia here and here. Sadly, it is in Czech, because the English variant does not have the equations in this format.
10
  • $\begingroup$ Thank you very much. I still need to read in detail to understand it all, but I think this answer contains what I was looking for. FWIW the Berd Air I mentioned in the question only has 80 kPa, so the moderately higher 148 kPa you got makes some sense. $\endgroup$ Commented Sep 7, 2021 at 14:01
  • $\begingroup$ For what it's worth, I do consider 1s significant, especially when working with 4s total layer times. If details are small, slowing down the nozzle further to extend the layer time does not work; due to slow speed it just puts more heat into the part, and the other option is doing a z-hop away from the part to let it cool, but that takes a lot more time and risks stringing. $\endgroup$ Commented Sep 7, 2021 at 14:05
  • $\begingroup$ On the machine I'm hoping to build in the future (delta with ultralight toolhead aiming for 600+ mm/s and 50k+ acceleration) sub-5s layers are likely to be the norm for a lot of the types of things I tend to print, too. $\endgroup$ Commented Sep 7, 2021 at 14:07
  • $\begingroup$ From what I understand, the 80 kPa advertised is relative to (on top of) atmospheric pressure, meaning ~180 kPa in total, whereas my value is absolute. Having even cooler air blowing across the print will most likely result delamination because of the internal stresses (one point at ~200 degrees, the other at ~ 0 degrees). Also looking at the Berd Air pump I seriously doubt it will create anywhere near 80 kPa. The motor looks to be a standard 775 brushed motor, which does not have the speed and power to create such pressure. $\endgroup$ Commented Sep 7, 2021 at 14:40
  • $\begingroup$ Not mentioning it is rated for 150 mA at 24V (3,6W) which is too little to even spin the motor without a load. As well as the rotor (which we cannot see) would have to be very well balanced not to vibrate violently. I say: save you money for something else. I would suggest increasing the flow rate instead of (dramatically) lowering the temperature. That would however increase the weight of the printhead. You will need to experiment to find a good compromise. $\endgroup$ Commented Sep 7, 2021 at 14:44
