When I'm using a .3mf file from Fusion 360 the circles are coming out as polygonal shapes that are very easy to see.
When using a .stl file from Fusion 360 the circles are near perfect the polygons that make it up are small enough that you can't see.
Is there any way to fix this in Fusion 360 to export the file properly or is it a problem related to PrusaSlicer?
