I recently got an Ender 3 Pro and had a blast with it for the first few days, but then I got greedy for a better print and threw off my calibration with some "upgrades" and ended up with some really nasty elephant's foot. The first 3 mm are all bubbly and uneven as if someone heated it up and squished it slightly.
I've read the other forums and have made sure my belts are tight, my bed is perfectly level, and my filament is just fine. I've tried using rafts to take the blow from the deformity and that usually helps but even with my initial layer horizontal expansion setting turned to -1, I'm still getting a little bit for flaring on the base layer on the raft.
The upgrades I got were an aluminum extruder housing (single drive) and Capricorn tubing.
After addressing the comments, now my corners on bigger prints come up and commonly fail even bed level tests... and the prints that do work (that I do print on a raft) are incredibly weak and break when I pull it off.
Furthermore, I’ve been fixing several things like suggested in comments and nothings worked, now for the most part every part I’ve printed that’s longer then 2 hours has failed.
Yes that is brand new capricorn tubing... the old fittings dug through my old tube and caused the filament to melt in the tube and ruin it.
