Recently I noticed a small issue with my Creality Ender 3, where I would come home and find one of the bed leveling wheels had fallen off. This one wheel keeps vibrating loose. It's not really affecting my prints for some reason, so I just kind of let it happen.
Yesterday I started an 8 hour print and left. When I came home, I heard a loud buzzing noise. I walk into my room and smell a burning smell. I see the printer has extruded plastic all over the place. PLA is all over the floor. The plastic its extruding is normal filament, not extruded plastic; the nozzle is gone. Not entirely sure how it came out, because it was tight.
I switch off the printer and assess the damage.
The nozzle is on the floor, covered in a big blob of plastic.
The stock fiberglass build plate is nowhere to be seen; I think it fell behind the desk the printer is on.
The friction surface below the plate is covered with scratches and blobs of plastic - that needs to be replaced as well.
Two of the bed leveling wheels are gone. One is on the floor, and the other probably fell behind the desk like the build plate.
The hotend fan has filament going through it. It's missing three blades. Two of them fell on the floor, and one fell into the hotend and melted, making the burning smell.
The hotend is covered in melted plastic.
The heater block has lots of plastic jamming the hole where the nozzle goes.
Where do I go from here? How do I fix this? Is this fixable?
What should I do to make sure this doesn't happen again?
