I have a Chiron from Anycubic and I have had some leveling issues in the last few weeks, however, I believe that I have sorted that. The layers attached to the base plate or the raft now come out very weird and I am uncertain why. I heard that this is caused by the extruder being too cold but I have turned up the temperature and nothing has changed. Could someone please help with this because I have a feeling this is the reason the prints are being warped slightly but enough to not fit together?
I am very new to all this and I have no one to help me with this, if you could help I would be very grateful.
3D printed model with badly extruded layer
My bed temperature is set to 70 °C and the speed is 50 mm/s. I manually leveled it afer the self leveling didn't work, the image shows the top layer of a very bad failed print that had the same settings as my other ones but this one specifically was worse. I use PLA and have the extruder set to a temp of 210 °C most of the time. I now have the base set to 80 °C due to when its lower, adhesion doesn't take place for some reason. There are no large overhangs on my models but it can comfortably do a 70ish degree angle with no major flaw. The extruder height is set to 2 mm due to some massive leveling issues I had before.
    $\begingroup$ Welcome to 3DPrinting.SE! Please add a photo so that we can see what might be the problem, could be adhesion, too much cooling or a too large of an initial gap, now it is guesswork. ALso add a little bit more information, what material are you printing, what are the temperatures, speeds, etc. $\endgroup$
    Nov 15 '21 at 22:45
  • $\begingroup$ Your description sounds like a 1st layer issue, especially since it is unaffected by extrusion temperature. Besides a photo printing details such as material of your filament makes a difference in how to approach this. The characteristics of your bed, such as temperature and anything to promote adhesion is important. $\endgroup$
    – Perry Webb
    Nov 16 '21 at 13:57
  • $\begingroup$ I could be too cold of the print bed. What temperature is your print bed set to? $\endgroup$
    – agarza
    Nov 16 '21 at 23:02
    $\begingroup$ @GuyTurner What's your Print material and the extruder temperature? What's the layer height? Are that unsupported overhangs? $\endgroup$
    Nov 18 '21 at 10:50
    $\begingroup$ @GuyTurner We really like to help out! Please add additional information, else this question might get closed (without enough information it would become speculation, as can be sen in the comments above). We would like to see the STL to confirm if there are overhangs, see an image of the first layer (initial layer height might be useful too), so flip the object around, need the extrusion temperature and the material. E.g. 70 °C bed temp. for PLA is a little high, but okay for PETG. $\endgroup$
    Nov 18 '21 at 11:51
What software do you use? Your nozzle diameter seems to be selected incorrectly or you have a slightly enlarged nozzle. Buy an unused nozzle and make your bed adjustments again.
Select correct a nozzle diameter (such as 0.4 mm, 0.6 mm) and slice your print again. For PLA, I suggest using 200-215 °C for better layer adhesion and using the fan to make prints look better.
That is an over extrusion and temp related issue, based on your picture. But to answer your question, make your layer height less and slow down your speed in the first 10 layers.
