The OP solved the problem by increasing temperature from 210 to "217-218". While it's good to have it working now, this likely suggests other problems with the printer thaat should be investigated.
If the change in temperature made the difference to get this print working, your extruder is just marginally able to push a sufficient amount of material through the hotend at the speed and temperature you're at. Normally I would expect an Ender 3 to do somewhat better, even with the stock extruder and hotend. Here are a few things you might want to check:
Is the filament properly dried? If it's absorbed moisture, the vapor phase transition will absorb at lot of heat from the hotend, making the effective extrusion temperature significantly lower than the block temperature. In my experience, it behaves like it's 20-25 ˚C lower than what you have it set to. You can kinda compensate for this by increasing the temperature (keeping an eye not to go over the safe temperature for the PTFE lining, max of about 250 ˚C) but the right solution if this is your problem is to dry your filament.
Is anything mechanically wrong with the extruder? A crack in the tension arm or weak spring can leave it very underpowered.
Are the extruder hob gear teeth clogged with plastic shavings? This will also leave it underpowered.
