I spend many hours tonight with a friend figuring out what's happening and solving my Anycubic Vyper firmware update. I had various issues :
  • While updating with the current version (2.4.5 as of today) I had many issues from no file update (the firmware update program display a list of file with 000 values on their right showing that nothing is processed and the checksum at the end having done nothing
  • Partial update leading to corrupted graphical interface freezing or blinking with locked actions/menus.
  • Never-ending update process blocking in "ICL" files (waited more than 40 minutes)
I solved this by searching clues on the internet (a Reddit topic) that lead me to the following configuration that worked for me (update completed, with sound at the end and all is functional in about 1 minute)
  • Format MicroSD card in FAT32, with allocation size of 4096 bytes
  • Use a small SD card (I failed many times with a 16GB one). It worked with a 8GB one for me. (this tip is not said in the Reddit topic but made the job for me)
  • $\begingroup$ I recently had an issue with a failing 16Gb card and found that the issue was that I had more than one partition on the card, just in case that helps somebody. $\endgroup$
    – UltraBob
    Jan 31 at 2:37
