I have a weird problem that I can't seems to find an answer for.
I'm using SuperSlicer with my Ender3 + OctroPrint setup.
The prints on the bed in SuperSlicer is perfectly straight
However, it seems that when my printer is moving in a straight Y-axis line, there is some kind of linear multiplier on the X-axis because it moves slooowly to the side causing the print to be pretty perfectly rotated on the physical bed as seen in Octoprint and also on the real physical bed (luckily my physical bed is slightly to large so I don't go outside of it).
I know there is some kind of setting for this which is used for Z-offset with probe, but I can't seem to find it, and it seems weird that it has been set for the X and Y axis. I don't know if that is what really causing this, because I've never touched those settings on this printer before 🤔
Anyone got an idea?
