Sometimes Cura will slice a model and have failed lines of code. After discovering this problem I have tried re-slicing and then the code will come out fine. The first picture below is the failure point in the code from the first time I ran Cura's slicing. The second picture is the exact same model that I ran a second time through Cura and it came out fine. Is there any settings/reasons as to why this is happening?
Note, that I am also using an Ender 3 v2. For the time being I suppose I will have to look at the full code ahead of time to spot failure points.
