I print a lot of stuff, and I was thinking I could get several magnetic bed-plates and when 1 print is done simply have my wife pull the plate off and stick on clean plate and start the print again. But a friend of mine says that won't work. Because even if the plates are made by the same manufacturer you can't guarantee the bed will be level. 〰
Has anyone ever tried this? 🤔
G29
before each print, if the idea is to change the plate while you are not at home and somebody less experienced need to do some tasks, that could be a solution. The crux is what kind of printer you have, please expand the question by edit! $\endgroup$
