I've been trying to print parts for Voron 2.4 but I'm having issues getting proper surface on walls. I'm printing with ABS. I couldn't find same problem all over the net looking at the images. Bed adhesion is quite good and printing temp is 240 °C and bed temp is around 100 °C. image 1
image 2
    $\begingroup$ I've seen this on ABS that has been sitting around absorbing moisture. Do you see or hear moisture cooking out as you print? $\endgroup$
    – Davo
    Mar 17, 2022 at 20:35
  • $\begingroup$ That block desperately needs a sock. :-) $\endgroup$ Mar 18, 2022 at 3:35
