I made a hook recently that I put up with VHB tape. It fell off around 2 weeks later (the hook come loose from the tape). It's just a hook for an empty backpack, so let's say it is under medium load.
Every time I design something like this I wonder if it helps to roughen up the surface before applying the tape. I'd imagine that the tape grabs onto grooves made with a knife or sandpaper but I am not sure tbh. I've seen some videos where someone preheats the tape before applying it but without explaining why.
Does anyone know how that works best?
If you ook into the VHB design document, the section "How to Prepare Specific Surfaces" describes how to treat the surface:
For higher adhesion, a primer should be used according to the document.
This reference describes that roughing up plastic parts can be beneficial for the adhesion of some tapes:
Abrade the Surface: Roughing up the surface (i.e. sanding) will loosen up any accumulated dirt, rust, or chipped paint. It will aid in the adhesion to painted surfaces or plastic items. A finely- abraded surface with shallow scratches created by a circular motion (rather than straight lines) has the best potential for a strong and persistent bond. This method can create up to a 40 % increase in surface area and can result in greater immediate and long-term bonding potential. Scrub pads, fine steel wool, or sandpaper can achieve the right level of abrasion. A palm sander could be helpful for larger jobs. Avoid using coarse abrasive materials because a too-rough substrate may inhibit the adhesive flow onto the surface. Always clean with the IPA/Water solution, or other solvents, and make sure all loose particles are removed. While it is not typical, some high-bond tapes adhere best to smooth, glassy surfaces, so double check with the manufacturer before you abrade the surface and compromise the bond strength.
Both references describe the use of a cleaning solution based on 50 % water and 50 % IPA.
A higher temperature is beneficial for obtaining the bond strength faster, the VHB design document shows that increasing temperature shortens the time when the full bond strength is reached:
