Bought a new printer. When this problem has happened anywhere from the third to the twentieth layer up. An excess of filament suddenly exits the nozzle, often pulling the print from the bed when the nozzle moves away. The only advice I've found so far is that the nozzle or hotend may have damage, but I didn't find any when removing them to examine them. I've tried a few different ranges of settings. Guidance would be appreciated.
I'm using a Creality Ender 3 with out-of-the-box equipment and slicing with the most recent Creality Print version. Settings are default (bed: 70 °C and hot end: 200 °C).
Here's what I get if I set everything to default, switch filament spool, and use a .gcode file that was sent in-box from the manufacturer. There was not really ever anything printed, since the blob was stuck to the nozzle and was dragged around in three dimensions until I stopped the printer.
