I am new to 3D printing and having a strange issue I don't understand and would love some help with. I have an Ender 3 Pro and when I use the settings 200 °C & 60 °C it prints fine. However, I want to change the bed to 55 °C as the bottom layers are melting a bit. I changed this in Cura to 200 °C & 55 °C and get a thermal runaway after 20 minutes or so. I hit resume and the same thing after about 20 minutes, however, the times vary.
I did a PID using the same set temps 200 °C & 55 °C and still thermal runaway. So I changed all the numbers back to 200 °C & 60 °C and ran a PID on this original temps and ran perfect (except for the first layers melting a bit)
The odd part is the bed temp holds fine when adjusted to 55 °C, it's the hot end that starts to drop a few degrees (5 degrees) which triggers the runaway. Is this a fan issue (currently at 100%)? Before I started changing things I wanted to ask here.
Looking forward to your feedback. BTW I am able to change the PID right on the machine and have no experience altering G-code or the knowledge but am willing to try?
