My printer (Ender 3 S1 Pro) only has a touch screen. When I use the pause at height command, the print pauses properly. However, the screen only displays stop and pause "buttons". Neither of these options allows me to restart the print. Can anyone suggest a solution to this problem?
I found that if I use Cura to generate the pause at height script then edit the G-code file and change the M0 code to an M25. Next, you must use that edited file to print from an SD card. When the printer pauses and you are ready to continue the print (while connected to a computer with a USB cable and with Cura open), select the Monitor tab in Cura, type M24 in the Send G-code window, and press the return key on your computer.
