I'm having a lot of issues leveling my printer and one failed print came out like this. Is there something wrong with the surface that I need a new bed? This happens to me quite often and I literally can't get it off.
1$\begingroup$ What type of filament are you using? $\endgroup$– agarzaMay 28, 2022 at 19:06
$\begingroup$ PLA, don't know the specifics but its silk gold $\endgroup$– desperrrrMay 28, 2022 at 19:08
$\begingroup$ Interesting, I had heard that some filaments adhere really well to PEI sheets, but not PLA. Maybe the nozzle is too close to the bed and therefore sticking too well. $\endgroup$– agarzaMay 28, 2022 at 19:10
$\begingroup$ Are you asking what is causing the filament to stick? or are you asking if the adhesion is not working properly and therefore need to get a new magnetic bed? $\endgroup$– agarzaMay 28, 2022 at 21:32
1$\begingroup$ @agarza: That's not PEI. It's textured "buildtak clone". $\endgroup$– R.. GitHub STOP HELPING ICEMay 29, 2022 at 16:44
Print the print once more. the first few layers will adhere to the excess material and you can then peel it all off.
$\begingroup$ This is the answer though. $\endgroup$ May 29, 2022 at 14:46
If it's flat so you cannot scrape it off you can just print over it. No need for a new bed.
Check your levelling first because if it's sinking into the bed then the nozzle is far too low and you can end up with a scenario where it rips the bed material when you remove a print.
