I have radial fan with 2 pins connector and always kept it connected to GND
/5V
pins (marked J5 at the left bottom on pinout image for my controller board).
I've stumbled upon the USE_CONTROLLER_FAN
feature of Marlin which allows setting some pin to be used for PWM-controlling a control board fan. I think SERVO0_PIN
should do fine (D11
at the bottom center on the pinout image), but I'm not sure how to connect it.
- Should I split connector and use
GND
+D11
pins? - Or should I use some proper PWM fan for that (which are always 4pin and then how would one connect THAT to those pins?)
- Is it safe to run a fan directly from board pins or should I resort to using either unused MOSFET outputs (e.g.
FAN
MOSFET pin marked asD9
on the left)? - Should I use dedicated MOSFET board to drive that fan using that SERVO0_PIN?
