-1
I don't have much space on my PC. Is there an online conversion tool for .stl that works? I had tried many but they crash every time. Maybe my file is too large.
  • 4
    $\begingroup$ Convert to STL or convert from STL? Convert to/from what format? $\endgroup$
    – fred_dot_u
    Jun 21 at 8:26
  • $\begingroup$ Please edit your question and clarify what you are asking about (don't list them in the comments). What online tools have you already tried and why did they crash? - if we know those then we will know not to suggest them again. $\endgroup$
    Jun 22 at 6:25
If online conversion crashes then that is usually an issue with your file having too many errors.
Size is a lesser matter, online converters clearly state size limits. So if your file is larger than the stated limit, don't try and convert it there.
