Just installed and set up a 3Dtouch on my home-built Prusa. I followed several articles as well as YouTube videos. I can get ABL to work well but printing has become a problem. Each print starts then stops every few seconds and then continues. Having checked a terminal the motherboard is running an M119 every so often and reports the Z endstop triggered. This continues throughout the print stop/starting. The setup worked fine with the original Pinda and steel sheet, but I wanted to change it to a textured glass for better adhesion.
Tech info:
  • Prusa Mk3 clone
  • 3Dtouch
  • BTT SKR1.3
  • Marlin 2.1.
  • Mattercontrol (slicer)
  • $\begingroup$ Do note that you cannot use the M119 when you use a touch sensor, it doesn't give you information on the Z-axis endstop status. $\endgroup$
    Jun 26, 2022 at 21:36
  • $\begingroup$ Agreed. I thought the reporting to the PC might be interrupting the print for a second before continuing. $\endgroup$ Jun 27, 2022 at 9:00
  • $\begingroup$ I seem to have narrowed it down to Mattercontrol. Using Cura as the host, small test prints work fine. $\endgroup$ Jun 27, 2022 at 12:11
