I know that a single mixing nozzle with dual filament input can blend them in order to make gradients. I also know that IDEX means you have two independent nozzles and you can make objects with different materials (or colors).
But I don't understand if an IDEX printer can still "mix" (on the layer of course) the two filaments to create a gradient. My common sense says it's not possible, but I didn't find a proof of that.
I'm NOT interested in a mixing nozzle as most of the time I will need two different kind of filaments. The gradient with IDEX is just a "nice-to-have" feature. Not mandatory, but I would know before choose my next printer.
  • $\begingroup$ There's much better ways to get gradients or indeed full colour pictures that only require one nozzle $\endgroup$
    – Kilisi
    Sep 13, 2022 at 8:35
  • $\begingroup$ @Kilisi it would be useful to add a link to some resources then $\endgroup$
    – Mark
    Sep 13, 2022 at 8:48
  • $\begingroup$ Just commented because it only touches the question tangentially, and I don't know if the resources exist as far as I know it might be just my lot $\endgroup$
    – Kilisi
    Sep 13, 2022 at 9:34
Consider the task from the creation reference. An IDEX printer requires the slicer to direct each nozzle to a specific location of the model while it is being created. No true gradient could be accomplished as it would require both nozzles to be in nearly-instant-extrusion proximity.
I suppose one could create a matrix of colors in a manner similar to that of RGB LED color displays, but that's a severe stretch of the imagination. It would require perhaps a strong understanding of full g-code control to place the individual lines. Additionally, there would be a limitation to two colors and the combinations thereof, although with the bi-color Quantum style filament, results might be interesting.
