I have an Ender 3 V2 Neo. I have installed the Creality dual Z-axis upgrade kit (with a second Z stepper motor) and third-party anti-backlash nuts. Only afterwards did I discover that users were reporting Z-axis sync problems developing between power cycles (which I have confirmed firsthand).
One solution I came across is to install a kit which uses just the original Z stepper motor with an additional Z screw and a sync belt connecting both Z screws.
Another solution I came across was using the G34
command to auto-align Z steppers. Then I discovered that to use G34
, I would need to upgrade to a third-party motherboard with dual Z stepper drivers.
Both options are about the same cost.
If you have experience with either or both options, I would appreciate your feedback on the pros and cons of each option.
