I have an Ender 3, I changed its extruder for one metallic one. In my last prints, I am getting issues at the same height. The extruder can't pull the filament in for that z position. I cleaned the Z axis, applied oil, and adjusted the eccentric nuts. I have minor improvements but still have many issues with my prints. I am thinking of changing to double z-axis, but I'd like to use my printer now.
This is my printer. enter image description here enter image description here
    $\begingroup$ Welcome to 3D Printing Stack! Can you post a photo of your filament path? This seems like you might have something jamming up your feed at a certain Z height. $\endgroup$
    – Zeiss Ikon
    Commented Sep 27, 2022 at 16:03
    $\begingroup$ Is it every print that fails at this Z height, or just every attempt of this particular print? Whatever it is, this is an extrusion issue, not a Z motion issue. The problem is not the rollers and will not be solved by dual Z. $\endgroup$ Commented Sep 28, 2022 at 1:10
  • $\begingroup$ @ZeissIkon I double-check the filament track. In theory I fixed it already. $\endgroup$
    – dobleUber
    Commented Sep 29, 2022 at 3:19
  • $\begingroup$ @R..GitHubSTOPHELPINGICE every print in the last three weeks have the same issue. You are right. I am gonna post more pics soon. Thanks. $\endgroup$
    – dobleUber
    Commented Sep 29, 2022 at 3:21
  • $\begingroup$ What do you mean by "In theory I fixed it already", if you fixed this please share through an answer. Both filament track and filament spool (winding) look too good to explain extra resistance caused by entanglement or kinks. $\endgroup$
    Commented Sep 29, 2022 at 17:49
I fixed this issue today on two printers.
One was failing first or second layer, the other after 1/2 an hour or so. After trying everything else I traced the cause to changing the nozzle to cheap steel ones. Changed back to the old brass ones and both printers are working fine.
Unsure what is wrong with the steel nozzles, I bought 10 of them online for peanuts, but happy to be printing again.
    $\begingroup$ How did you determine that your issue was the same as OP's? $\endgroup$ Commented Oct 4, 2022 at 5:10
  • $\begingroup$ @R..GitHubSTOPHELPINGICE because it looks like roughly the same description and has the steel nozzle change in common. I was looking at everything else before realising it was the brand new nozzles. Filaments, heat, levelling mechanicals etc,. Then finally fixed one today, and went straight home and fixed the other in a few minutes $\endgroup$
    – Kilisi
    Commented Oct 4, 2022 at 5:40
