I would like to print an object on an Elegoo Mars 3, object which is generated layer by layer via other means.
So as input I have a series of BMP or PNG black and white images, one for layer, and I need to somehow assemble them to obtain a CTB printable file.
The solution can either involve generating a 3D model to be loaded in Chitubox, or it can involve generating directly a CTB file.
How can do that?
You can do this with the open-source tool UVtools. I don't know if there is a built-in method but you can certainly achieve it by writing a short script.
If you don't find the option in the menu, you can ask in the forum. Tiago, the father of UVTools, is a very kind and knowledgeable person.
