I’ve recently obtained a Creality Ender-3 V2 3D printer and have tried setting it up. With it came 2 modifications (CR Touch auto bed leveling kit and dual Z-axis kit).
The installation of the dual Z-axis kit was fine, and so was the CR Touch. Before I tried to install firmware for the CR Touch, the printer seemed to do everything fine. On activation, the Creality startup screen appeared with a loading bar. After the bar loaded it gave me the basic options. I was able to check and see that the current firmware version was 1.0.4. Also, during the wiring of the CR Touch kit, I checked the motherboard version, which was version 4.2.2. After it was functioning fine, I decided to install the CR Touch firmware.
When I tried to install the firmware for the first few times into the printer's SD card reader, nothing happened. I then decided to try plugging it into the card reader inside the display. When I booted it up this time, it displayed the Creality startup screen with no download bar, three “0.00” at the bottom which would flash to “???” every second, and a number above those three things which switched from 21 to 22 every second or two. After some time the number stuck at 22. After this, I took the card out of the display and turned the printer off. Since then, the printer has done nothing.
Now when the 3D printer turns on, it’s just the Creality startup screen with no loading bar. It stays on this screen and nothing changes, nothing happens. The printer also does not seem to connect to my computer (USB or Wi-Fi), does not accept anything from the card reader on the front of the machine, and does not accept anything from the card reader inside the display.
Ever since this has begun, I’ve done the following:
- Inserting the card with many different pieces of firmware into the display card reader and front card reader. Result: Nothing happened.
- Inserting the card with a .txt file containing
M502 M500
(factory reset code and setting save code) and renaming it to.gcode
. Result: Nothing happened. - Connecting a computer to the printer via a USB cord. Result: Computer detects nothing.
- Sending
M502
andM500
to the printer via Creality Print software. Result: Nothing happened because no printer was found. - Checked the file system and partitioning style. Result: FAT32 and MBR.
- Used Pronterface to try and connect to the printer. Result: Weird error message reading “Update failed, no SD/TF-card or error.” I tried this with and without the SD card in both the display card reader and the front card reader.
- Have tried Googling many different answers to this issue. Unable to exactly pinpoint anything the problem. I found one Reddit post about the “Update failed, no SD/TF-card or error” error, but it does not have any helpful replies. Result: Nothing helpful.
It’s been 2 days of continuous work on the printer and nothing has come about to signify an end to this suffering besides the “Update failed, no SD/TF-card or error” error. I’m tired of nothing working and unrelated answers, so I’ve decided to ask the question myself.
