I have a model of a building that has a fence around the roof. The fencing must have Print Thin Walls enabled to print at all, but the result is patchy:
Screenshot of Cura's Preview of a model of building with a fence on the roof
You can see the blue outline of the fencing from the model selection itself, but the walls in red are not filling it consistently despite each fence post being the same size. I tried turning Minimum Feature Size to 0.0 mm as well as Minimum Thin Wall Line Width to the nozzle size of 0.3 mm, but no luck. Is there some Cura setting I am missing or some other cause for this issue?
I intend to print with PLA using a Creality CR-10S. I'm slicing using Cura 5.2.1.
