I am following the tutorial Slicing a 3D object to SVG.
My code looks like so:
import("/Users/petarivcec/Desktop/art/king of sun/1.stl");
 z_min = 0;
 z_max = 100;
 x_max = 50;
 y_max = 55;
 slice = 1;
 n = floor(sqrt((z_max - z_min)/slice)+1);
 for(z = [-z_max:slice:z_min]) {
   i = (z + z_max) / slice;
   x = x_max * (i % n);
   y = Y_max * floor(i / n);
   translate([x,y,0]) {
       projection(cut=true)
           translate([0,0,z]) thing();
When I hit Render, then I get warnings like:
WARNING: Ignoring unknown module 'thing' in file , line 16
I guess that I just need to figure out how to run the loop on my imported stl instead of the non-existent thing module which exists in the example code but I'm not really sure.
According to the linked site, it appears that you are missing the "identifier" module for the item to be cut into layers, aka thing();
module thing() // a random object, in this case a hollow sphere on top of a hollow cube.
I suspect that if you encase your STL import in a module named thing() you will have a solution. An alternative to naming the module would be to remove the thing() call and use the import at that specific location.
The second sample in the linked site is a failure similar to your for the same reason.
  • $\begingroup$ importing within the loop solved the issue for me $\endgroup$ Mar 1 at 16:56
