I'm using a Creality Ender 3 printer with 1.75 mm PLA filament. The print model has a 0.8 mm thick rectangular base. The design contains a couple of shapes (mainly circles and a cross) that stick out an otherwise flat rectangle. The circles and the cross stick out by 0.8 mm. The bottom of the model is flat.
Is it possible to stack multiple models on each other using Cura if the top of the model is not flat (as shown in the image below)?
