My Flsun Q5 is WiFi-connected to Cura 5.3 (The blue dot is on, near the printer name).
After slicing an STL model I get the choice of sending it to the printer, the process starts but suddenly stops with the following error: [send file to printer failed. check printer SD card]
This happens with or without an SD in its slot.
