I can’t figure out what the issue is. The far side of the bed (Y-axis) print won’t adhere because the extruder is too far off while on the near side is too thin. I have tried all the troubleshooting tips I can find online and nothing worked. Even as a last resort, I tried shimming the far-side bed screws and still have the same results after auto bed leveling.
Photo of the first few layers of a printed model but front edge is very thin on the build plate
Another photo of a printed model again with a thin front edge
  • $\begingroup$ Hi Jeff, have you found and fixed the problem? If so, has the answer below led you to the solution? Please vote to accept the answer so this question is not bumped up once in a while and can be removed from the unanswered question list. You may even add your own solution and accept that after 48 hours! If you have not been able to address the problem please update your question. $\endgroup$
    Commented May 2 at 7:29
If you did not resolve this, you can try a couple of things: You'd need OctoPrint and the "bedvisualizer" plugin installed. I've had a similar problem with my Kobra standard and found out that it was totally off-level. If the issues persist, please download/install both and send a screen capture of the bed level so we can go from there!
