Using Cura, I'm trying to change the direction of just a section of my print. I want it to print zig zag instead of straight lines. Just the way my part is intended to be used it'd be much better to do it like that. Is this possible?
I tried using a cutting mesh, and changing the top/bottom line direction, and many other things with the word direction in the name, I also tried rotating the part (not that I thought it would make a difference).
It was requested I add a file to test with. It's not the same model in the picture, but should work just the same for testing purposes. It should be oriented so that there is an overhang.
Test File
    $\begingroup$ Can you link to the model? E.g. is it freely available? Otherwise, create a model with this specific problem you can share. We can then try to work it out, I have some ideas to solve this. $\endgroup$
    Commented Oct 6, 2023 at 9:48
  • $\begingroup$ The test file is different in that the overhang is much thinner on the example image shown in the question. I've made an example based on the shown image which I use in my answer. $\endgroup$
    Commented Oct 28, 2023 at 7:21
Yes, this is perfectly possible to do in UltiMaker Cura. The technique to use is described in question Different infill in the same part and explained in this answer for 2 separate slicers this answer focuses on the Ultimaker Cura slicer per the question.
Considering the following example geometry based on the sliced image from the question (disregarding the linked test file to better comply to the question at hand):
In Cura this model can be sliced using a support blocker that has the Per Model Settings configured with the Cutting mesh option:
It is key to use the Cutting mesh option and add properties you can change for Wall Thickness, Wall Line Count, Top/Bottom Thickness, Infill Density, Infill Pattern and Infill Line Directions. If these are not visible, you can add the settings through the Select settings button.
  • Wall Thickness: you don't need to change this option, this is overruled by the Wall Line Count setting
  • Wall Line Count: set to 0 (you do not need walls in the small area)
  • Top/Bottom Thickness: no top or bottom shells are required
  • Infill Density: set to 99.9 %! beware to not set this to 100 % as this triggers Cura to use the Lines infill pattern while you are interested in the Zig Zag line style
  • Infill Pattern: set to Zig Zag
  • Infill Line Directions: [90,90] (or [0, 0] depending on the orientation of the print object sliced in Cura); this determines the alternating pattern of the Zig Zag, if the values are the same, each layer is sliced equivalent otherwise each other layer is rotated 90°
Upon slicing this print object you will get the requested results:
So, yes, you can change the direction of the small area you are interested in making clever (mis-)use of the options Cura provides.
