In addition to the question Does rPLA stand for Recycled PLA, or is it a different type of material?.
Does PLA lose mechanical properties when it is being recycled into rPLA? If so, how often can it be recycled before being unusable for recycling? And how would filament manufacturers know or account for this? How would they know if I returned the new PLA or rPLA waste? What if, in theory, the same rPLA batch is sent back repeatedly for recycling?
Yes, recycled PLA loses mechanical properties.
According to Dr. D-Flo's excellent video on Recycling 3D Prints and Waste plastic into Filament (PET & PLA) it loses mechanical strength during every thermal cycle - i.e. when it is printed, when it is melted down for recycling, when it is next printed, etc.
Manufacturers account for this by mixing in "virgin" PLA. So "recycled PLA" is really a mix of recycled and new PLA. This will lessen the extent to which the recycled portion will affect overall strength of the result.
I do not know if/how manufacturers would account for how many thermal cycles the PLA you supply has been through.
If the mix of virgin/recycled PLA has more virgin than recycled, then it may not matter. If the mix favoured recycled then each batch would be worse than the one before. I suppose manufacturers can test a sample from the beginning of their re-extrusion, and if they find it too brittle (etc.) they can change the mix before continuing.
  • $\begingroup$ Nice answers Rob. Thank you! $\endgroup$
    – Bob Ortiz
    Dec 9, 2023 at 0:32
