I am trying to get a file produced by a manufacturer and they want the detailed dimensions of the model, it is a complex ID card badge holder and I am wondering if there is an easier way to get a dimension sheet. I have used Fusion 360 to get like face and edge measurements but there are a lot and I was seeing if there was a better way to do it?
  • $\begingroup$ Can't you make a technical drawing in Fusion? The design tool is meant to produce drawings for fabrication shops. $\endgroup$
    Commented Feb 9 at 16:44
  • $\begingroup$ @0scar I did not create the file in Fusion 360 it was just an STL file that I aquired. $\endgroup$
    – Ryan Vogel
    Commented Feb 9 at 18:56
  • $\begingroup$ An STL can be transformed into a solid, and from a solid you can make drawings. Can you add an image of the STL, or a reference to the model? $\endgroup$
    Commented Feb 9 at 23:32
