I'm new to 3D printing so I'm not sure if I'm missing something glaringly obvious. It seems to me ideally you'd design models for 3D printing in ways that use joints and whatnot to avoid the need for supports entirely. Or you would model small specific supports for that model where and as needed. This way you reduce cost, print time, blemishes, etc. Which is all very well and good if you're designing for print runs. But if you're just making a one-off or you need a handful having support makes sense. My question then, would be rather than dealing with the problems of traditionally generated supports or having to deal with print time and added costs for each print, what if we could use prepared blocks to support bridging, etc? Perhaps with screws to adjust the height and angles of some wedges, and printing a thin outline at the start and pausing after the first couple of layers to place blocks within the outline. Would this be precise enough to avoid most issues and support bridging? In my mind, it seems like it would work but as I say I've only had my first printer for a few days.
I presume that the biggest issue would be the print head colliding with the support structure but that could be adjusted in the software I reckon. There is already the print one object at a time thing going on (although I've only tried that once and the head did collide with the first object...) Perhaps pausing and adding support blocks when approaching the required layers would be better than having it on from the start to reduce travel times. It still seems feasible to me.
