I have a strange issue with my heated bed. It has been working well for a long time, but recently it has developed an issue where the temperature reported by the thermistor will occasionally jump by around 10 degrees.
My setup is a 600W, 240V silicone heater mat, with integrated 100k thermistor, that is switched with a solid state relay. The mat is fixed to a 4mm thick aluminium plate. It seems unlikely that these fluctuations are due to bad PID tuning since the reported temperature changes much more quickly than is physically possible.
I've checked the wiring, tried using a different thermistor port and making sure the connector was properly plugged in, but to no avail. The fluctuations are brief enough that they don't cause any problems when printing, but I'm worried about the issue getting worse.
I have a RAMBo board 1.1b, and I've tried using both the integrated 5V SMPS supply and an external USB supply.
The issue is not limited to the start of printing, the temperature reported can be stable for a long time before the issue pops up. The issue also occurs during cooldown (further confirming that PID has nothing to do with it):
In fact, the issue seems slightly more common during heat up and cool down, but is not limited to these times.
I would like to know what might be causing this issue, and if there's a way to solve it without replacing the thermistor (which would be a pain, since it's integrated into the heater mat).
