I own a delta 3D printer. The problem is that, at the beginning of a print the extruder outputs dirty filament. I want a clean filament flow at the start of my prints!
How can I make the hotend exit the print surface (glass plate) by 10mm, extrude the bad filament and go back to printing again? Can this be done with G-code?
My Z high is 190 mm and the glass plate diameter is 120 mm. I'm using Marlin + Ramps 1.4.
I'm using Repetier-Host and CuraEngine as Slicer, but I really would like a G-code that can work on multiple environments like Cura and Repetier. I just want to add it to the start G-code and print!
